White space between lists in Report
IvonaK
Member Posts: 115
Hi to all,
I have make a report from scratch using tables "Purchase Header Archive" and "Purchase Line Archive ". I have add 2 lists. (list 1, and list 2) . List 1 group by:
=Fields!Purchase_Header_Archive__Buy_from_Vendor_No__.Value
and the List 2 group by:
=Fields!Purchase_Header_Archive__Buy_from_Vendor_No__.Value.
=Fields!Purchase_Header_Archive__No__.Value
In the List 1 I have 2 table and List 2. In the List 2 I have just 3 tables (like picture 1).
On the List 1 I have put Filters: =Fields!Purchase_Header_Archive__Buy_from_Vendor_No__.Value > ""
On the list 2 in the filters I have put:
=Fields!Purchase_Header_Archive__Buy_from_Vendor_No__.Value > "" and
=Fields!Purchase_Header_Archive__No__.Value > ""
also in the table propertis in Filters I put the same code.
but I still have white space between lists.
Any advance,
Any advance,
I think the filters used for list 2 have to be applied as visibility condition on row groups, otherwise space is allocated anyway.* Daniele Rebussi * | * Rebu NAV Diary *0
I put visibility condition on row line where visibility=true , also I put visibility condition on Table Propertis but still does not work0
