backing up data error in sql 2005
Amaraa
Member Posts: 153
My original database is in native. Now I want to make it in SQL 2005.
In native backup restore works fine.
But once I restore the data and try to backup from sql it gives me (The error (1190 in module 19) ...).
So, then I restored the prepared backup in native and tried backup worked fine.
Is it because of the collation?
My sql database is with windows collation and "Validate Code Page" is unchecked.
I went through migration objects which checks the data and there was no error at all.
How can I make it work. There is something different between native and sql.
Any ideas appreciated,
Amaraa
Amaraa
AAs Shedman points out that link explains the error. It is very likely to be either a codepage error, or a case error. For example some characters such as ì -> Ì (an i with a reverse accent) convert to different uppercase in windows and Native databases.
To fix this you should locate the incorrect conversion in the Native database and change it to something else.
The most likely place to find the error is in a fields like Customer Search Name or Vendor Search Name.David Singleton0 -
Is there any collation difference in sql and native?
Maybe I'm giving wrong understanding.
So, what I want to do is navision backup from sql database. nav backup works fine with the native db.
What could cause the problem???
Please, give me a hint0 -
Amaraa wrote:Is there any collation difference in sql and native?
You know an error message might help. Are you being lazy or is it some big secret. You want help but wont tell us what's wrong. ](*,) ](*,) ](*,)David Singleton0
