Getting error while running a Jobqueue via Jobqueue dispatcher code unit
Hi All,
in NAV 2009,I am getting a below error while running a Jobqueue via Jobqueue dispatcher code unit(448)
This message is for C/AL programmers: Could not create an instance of the OLE control or Automation server identified by GUID={3B311C81-140E-11D5-8B18-00D0590B4EC5} 1.0:{3B311C92-140E-11D5-8B18-00D0590B4EC5}:Unknown Automation Server.Unknown Class. Check that the OLE control or Automation server is correctly installed and registered.
OK
Please suggest me some ways to resolve it.
Thanks in advance,
Jacob.A
    ArhontisArhontis Member Posts: 667
    edited 2019-06-19
    I guess you are missing the proper registration of the navision timer (look especially at @Kine's answer):
    https://forum.mibuso.com/discussion/comment/29868/#Comment_29868
    Jacob1227Jacob1227 Member Posts: 128
    Thanks, Arhontis.
    Now one new error is shown below while running the Jobqueue dispatcher code unit(448).
    The date is not valid.
    Please help me to resolve this.
    Jacob A.
    Sachin_Sachin_ Member Posts: 67
    Hello @Jacob1227,
    Does this user computer has different date format? if so change it to default server date format. That resolved the issue for us.
    Hi Sachin,
    The date format also correct.Still its showing the error .
    what about work date?
    From where i found work date?
    I am trying to run a code unit in nav today.so today is the work date. am i right?
    edited 2019-06-19
    work date you can find it from frontend of navision,can u share the screenshot of that for better clarity
    edited 2019-06-19
    That is updated automatically not manually.
    ok fine then Send a screenshot of the error
    Check this,
    edited 2019-06-19
    ok So You need to stop your Job queue and run it again it may work
    Still facing the same error :/
    how is it even possible which version of nav you are using
    NAV 2009R2.
    Is there anything i have to check in Codeunit 1(Application Management)?
