Problem importing XML with space char in decimal values
lzr
Member Posts: 264
I have an XML file where the thousand separator is coded like this
No matter how I do try to solve it with text strings, strpos etc I can't get it to work. Does anyone have an idea on how to import this?
XML:
<MASS>81 018,667297284</MASS>
NAV just gives me the error message:
You cannot enter 81 018,667297284 in Decimal
XML:
IF STRPOS(InMass, ' ') > 0 THEN
InMass := DELSTR(InMass, STRPOS(InMass, ' '), 6);
IF InMass <> '' THEN
EVALUATE(drawing.Mass, InMass);
Navision developer
Is it stil leaving a space in the InMass after 81 when you delete the string, as you say, you cannot enter 81 018,667297284 in Decimal
IF STRPOS(InMass, ' ') > 0 THEN InMass := DELSTR(InMass, STRPOS(InMass, ' '), 6); //Remove spaces inside the string //NewString := DELCHR(String[, Where][, Which]); //If Where contains =, then all the spaces are deleted from String InMass := DELSTR(InMass, '='); IF InMass <> '' THEN EVALUATE(drawing.Mass, InMass);
This should now have 81018,667297284 in the Variable INMass
HTH
DavidAnalyst Developer with over 17 years Navision, Contract Status - Busy
Mobile: +44(0)7854 842801
Email: david.cox@adeptris.com
Twitter: https://twitter.com/Adeptris
Website: http://www.adeptris.com0 -
Thanks but the problem is that this does not trigger:
I am guessing that it's a problem where NAV interprets as a special character. I have tried with just the strpos(InMass, ' ') but that doesn't trigger eitherNavision developer0 -
Can you screenshot the actual error message, is the value always to the same number of decimals or variable, and confirm that the comma ',' is the decimal point?
