Tapatalk
BubaBuba Member Posts: 24
edited 2011-05-04 in Feedback
Hello Admins.
One simple question, could you implement Tapatalk support for this forum?
This forum would be much handier if we all could access the site wherever we are.
The plugin is free for forums to use.
http://www.tapatalk.com/
    kapamaroukapamarou Member Posts: 1,152
    I would like that too! :)
    Thank you!
    Sent from my HTC Desire using Tapatalk
    Yes, thanks for the quick response and setup.:)
    Sent from my HTC 1 using Tapatalk
    No problem.
    The forum will look like this (thx to Buba for the screenshots):
    List of forums:
    Topic thread:
    Reply to a topic:
    The Apps can be downloaded through this link: http://www.tapatalk.com/mobile.php
    sorenhinrupsorenhinrup Member Posts: 136
    I get an error that there are some issues with the server, when i try to read a forum thread through tapatalk. I get unread threads without problems.
    Anyone knows what might cause this? I use tapatalk without issues for other forums.
    BR
    Søren Hinrup
    I have now updated the Tapatalk plugin to the latest version. Did it work?
    yes, thank you very much.
    PurpleHazePurpleHaze Member Posts: 42
    edited 2021-11-15
    10 years later... Could someone please confirm if this still does or doesn`t work? I am not able to find mibuso in tapatalk app...
    We had an integration with tapatalk before, when we were using phpBB as forum software. Since the migration to Vanilla forums in 2015, we are not on tapatalk anymore.
