Facing Problem in adding a new field in a table
hksharmaa
Member Posts: 55
I had created a new field in Item Table which is linked with my item. Now i want that in Item Journal line that when i select that item the new field that i had created must come there with the value
You have to add your field also to the Item Journal Line Table.
If you look at the c/al code on that table you will find
Item No. - OnValidate()
GetItem;
Item.TESTFIELD(Blocked,FALSE);
Description := Item.Description;
"Description 2" := Item."Description 2";
"Inventory Posting Group" := Item."Inventory Posting Group";
"Product Group Code" := Item."Product Group Code";
"YourField" := Item."YourField"; //add in your fieldinfo
If you don't have access to the code on the form you will have to create a lookup type flowfield.
Then add your field to the form.
Ps. Welcome to the forum.
Please use a more descriptive Subject line - so others in the future can find the answer if they have the same problem.
Please read the forum rules
http://www.mibuso.com/forum/viewtopic.php?t=9884
Enjoy!0 -
I have wtitten the code but i am not getting the value in my new field.............In the Item table there is a field called "Print Name". I want this field to come in Item Journal Line Table .....i have also created a new field in the Item journal line table named as "Print Name".as soon as i select the Item in the Item Journal line Table, the Print name should also come along with it along with the Item in the Journal item Table.0
Please edit your Topic title and change it something more meaningful. People don't tend to read/answer "Please help me" topics.0
In the Item Journal Line on Valiadate trigger of Item No. the following code is written:GetItem;
"Item Category Code" := Item."Item Category Code";
Add your line after the code
YourField := Item.YourfieldCA Sandeep Singla
http://ssdynamics.co.in0 -
It Worked .............Thanks A Lot.............
ssingla wrote:In the Item Journal Line on Valiadate trigger of Item No. the following code is written:GetItem;
Looks familiar
