Problem with automation and Excel
Alex
Alex Posts: 54
edited 2000-03-14 in Navision Financials
I have following problem i what to put in an Excel Cell
some Text that is larger then 250 Characters.
Like this way for Example
REPEAT
Text := Text + Artikeltext.NEWTEXT;
//maybe If text > 250 Then ....
UNTIL Artikeltext.NEXT = 0;
xlsheet.Range('B' + FORMAT(i)).Value := Artikeltext.Text;
xlsheet.Range('B' + FORMAT(i)).ColumnWidth(30);
i:=i+1;
If the Variable goes ofer 250 Character i get an Error
Okay, that logic !? But now, how can i put more Text in then
Excel Cells that which are right now filled with some character ... ?
Greetings from Germany
Alex
Best regards
Alex Schubert
ERP & Navision
Dolphin Communication Technologies GmbH
Otto-Hahnstr. 1 c
D-69190 Walldorf
  • Dennis
    Dennis Posts: 25
    The problem is that a textvariable cannot exceed 250 chars. You should try to use xlsheet.Range('B' + format(i)).value := xlsheet.Range('B' + format(i)).value + Artikeltext.NEWTEXT; instead of Text := Text + Artikeltext.NEWTEXT;
    Good luck
    Dennis van Es
    Qwinsoft BV
    The Netherlands
  • Dennis
    Dennis Posts: 25
    Good luck
    Dennis van Es
    PerCom: Research & Development BV
    The Netherlands
    Dennis van Es
    Qwinsoft BV
    The Netherlands
  • Alex
    Alex Posts: 54
    Thanks Dennis,
    i try this variant also,
    but i get following Error : Joker + Text does't work together, and if i try it in this way
    xlsheet.Range('B' + format(i)).value := xlsheet.Range('B' + format(i)).value + xlsheet.Range('B' + format(i)).value( Format(Artikeltext.Text));
    I get an error like: Joker + Joker doesn't work ...
    Anyone know a solutiopn ?!?!?
    Best regard Alex
    Best regards
    Alex Schubert
    ERP & Navision
    Otto-Hahnstr. 1 c
    D-69190 Walldorf
  • <marquee align="middle">TEST</marquee>
