DB test Problem, only when running maximum
kredekrede Member Posts: 9
edited 2005-11-26 in Navision Attain
Im new to navision and a have this problem when running hotcopy (with test=maximum)?
test=normal generates no error.
Backup W1 3.10.A
Backup Tool for Navision Attain version 3.10.A Copyright (c) 1987-2002 Navision a/s.
Backup started at 2005/11/21 19:35:16.
Starting database test with option: maximum.
'Object' does not exist.
Type: Report, ID: 11
The Rapport-id field in the Rapportliste table has a table relationship to the ID field in the Object table.
'Rapportliste' has the following identification fields and values:
Menu-id='100',Linjenr.='220000'
Backup ended with an error at 2005/11/21 19:58:44.
:shock:
  • roshandilrukroshandilruk Member Posts: 51
    It seems this is a table relation error, but you can always take the back up by using minimum option, the data will be still saved.
    Roshan
  • kredekrede Member Posts: 9
    Okay, running with "normal" option does also make a backup error-free.
    But should I care about the table relation error?
    None of the users have been complaining about it.
  • Marije_BrummelMarije_Brummel Member, Moderators Design Patterns Posts: 4,262
    The error says that in the report list there is a non-existing report, just remove this report from the Financial menu report list.
    Missing tablerelations are not a big problem, almost every database has some. Removing them can be done but is not nessesairy.
    Okay, Thanks O:)
