Problem using TLS12/13 for connection with webService
AitorEG
Member Posts: 342
Hi everyone,
I am working with NAV 2018, installed windows server 2012 R2 standard.
I have created a a few years ago an integraion with an external webService. it is working perfectly, but they are changing the security protocol to use TLS 1.2 or 1.3. The system administrators from the webService gave me a new URL for testing that we can connect via TLS1.2 or higher. I'm jsut changing the URL in my development, and I get this error(filtering traffic with fiddler):
This is the error in NAV:
"Error in call System._ComObjectSend with the message: Cannot finde the specified resource"
The code is like this:
It worries me that may be it will be an issue with the server, or any setting of it..
Any hint? Thank you all
ServicePointManager.SecurityProtocol := SecurityProtocolType.Tls13; IF ISCLEAR(XMLHTTP) THEN CREATE(XMLHTTP,FALSE,TRUE); XMLHTTP.open('POST', 'https://express5.xxx.com/expressconnect/shipping/ship',0,User,PSWD); XMLHTTP.setRequestHeader('Content-Type: ', 'application/x-www-form-urlencoded'); XMLHTTP.setRequestHeader('Host','express5.xxx.com'); XMLHTTP.setRequestHeader('SOAPAction', 'https://express5.xxx.com/expressconnect/shipping/ship'); XMLText := 'xml_in=' + XMLDocDotNet.OuterXml; XMLHTTP.send(XMLText);
I've changed the develompnet to use DOTNET instead of automation. This is the new code:ServicePointManager.SecurityProtocol(SecurityProtocolType.Tls13); HttpWebRequest := HttpWebRequest.Create('https://express5.xxxx.com/expressconnect/shipping/ship'); credentials := credentials.NetworkCredential(User,PSWD); HttpWebRequest.Credentials := credentials; HttpWebRequest.Method :='POST'; HttpWebRequest.Accept := 'application/x-www-form-urlencoded'; HttpWebRequest.ContentType := 'application/x-www-form-urlencoded'; StreamWriter := StreamWriter.StreamWriter(HttpWebRequest.GetRequestStream); StreamWriter.Write(XMLText); StreamWriter.Close; StreamWriter.Dispose; HttpWebResponse := HttpWebRequest.GetResponse; response := HttpWebResponse.ToString;
And I get this error:
"...cannto create a secure channel..."
Any tip?
tell dotnet it should use tls1.2 using this line of code:
ServicePointManager.SecurityProtocol := SecurityProtocolType.Tls12;
with these variables:
- ServicePointManager : System.Net.ServicePointManager
- SecurityProtocolType : System.Net.SecurityProtocolType
Remco_Reinking wrote: »tell dotnet it should use tls1.2 using this line of code:
Thanks for your answer. As you can see in my code, I've added that in the first line. But I've changed it to the line you are indicating, and the error still the same...
I'm starting to get desperate., I doubt if it might be an issue in the server or something...0 -
Must sayt that using the code I wrote first, or this last one (DOTNET instead of automation), I get the same failure in the fiddler0
Thehe web service is correct:
This is calling the old URL:
And this to the new one:
More than desperate....0 -
Hello @AitorEG,
In Powershell is pretty much the same code that you already has wirtten in NAV$request = 'THE XML TO SEND' $URL = "THE URL" $username="THE USERNAME" $password="THE PASSWORD" $uri = New-Object System.Uri $URL $req = [System.Net.WebRequest]::Create($uri) $req.Method = "POST" $req.ContentType = "text/xml" $SOAPAction = 'THE SOAPACTION' $req.Headers.Add("SOAPAction", $SOAPAction) $credentials = New-Object System.Net.NetworkCredential($username,$password) $req.Credentials = $credentials $writer = New-Object System.IO.StreamWriter $req.GetRequestStream() $writer.WriteLine($request) $writer.Close() $response = $req.GetResponse() $receiveStream = $response.GetResponseStream() $reader = New-Object System.IO.StreamReader($receiveStream, [System.Text.Encoding]::UTF8) Write-Output $reader.ReadToEnd()
And about the TBAI send me a private message and we can talk.
Regards.
Hi @ftornero ,
Sorry, but I got more info that could help to understand the problem. First of all, wih the PS script shown before, if i call he old URL, works correclty, as I can see on the fidler.
My next step has been to try to see the soap call into fidler. Fidler wasn't filtering calls from SOAP, so looking into the net, I found to try to change this value from authomatic to:
and....
Seems that the conecction is stablished, but fails when sending the message...
I don't know if this will help to figure which is the error, but any new information is welcome...
hi @ftornero
We are testing against a rest API.
Anyway, is I use your example script against the old URL works correctly, but against the new..
And same adding:
[Net.ServicePointManager]::SecurityProtocol = [Net.SecurityProtocolType]::Tls12
Must say that all this test are donde in the server where NAV is installed, in my laptop for example, I'm not having any error with the scripts.
I'm running out of ideas, but with this last test with the PS script, seems to be something about the server itself, no?0 -
Thanks for all your tips @ftornero . I was expecting that from the very beginning, but as you know, a research is mandatory before talking about the server...
We will try to talk about this with the system administrator of our customer, hopefully we willl fidn a solutions as soon as possible.
Thank you again!0
- 320 Dynamics CRM
