Need help about help !
StaminosStaminos Member Posts: 68
Good morning,
I have an important problem with the generation of help file with gate.doc.
When I add new help files under \MBS\Client\FRA, Navision need install CD for each new session.
Our customer finds this procedure too heavy and doesn't understand...
Is this normal or not ?
Thanks for your help...
    1) Which version you are using?
    2) Check if the users have writing rights into client folder
  • StaminosStaminos Member Posts: 68
    Thank for your response.
    I use version 3.70 and yes the users have writing rights into folder.
    thank a lot
    Staminos
    It is Terminal server installation or installation on common PC?
    Yes, it is a common installation on client set.
    Staminos
