Problem with piece of code
Sv1N2S
Member Posts: 13
Hello All. I have some problem with code:
FOR I := 255 DOWNTO 128 DO CharTXr[CharTX] := I;
Its strange Because in nav2009 it is work good, but in 2017 I get error like on screen. Can You explain me why?
The expression "CharText[someinteger]" returns char data type, not an integer, and requires integer to index the CharText variable. Apparently NAV 2017 cannot implicitly convert from char data type to integer in this particular context. I guess adding an intermediary integer var like this
BEGIN idx := CharText[i]; CharText[idx] := i END
should help.Slawek Guzek
Dynamics NAV, MS SQL Server, Wherescape RED;
PRINCE2 Practitioner - License GR657010572SG
GDPR Certified Data Protection Officer - PECB License DPCDPO1025070-2018-030 -
Thanks for your reply. It works0
