Using Standard NAV 2017 for Project Management
lchronister1
Member Posts: 1
Happy Friday all!
Client requirement is to track tasks and their completion using standard NAV or with little modification. Has anyone used Jobs or Workflow or other to solution a requirement like this?
General setup they are looking for: Task with a resource assigned to a work order, the work order assigned to a project, the project/work order would be assigned to a Customer set up on the system. Reporting on status of tasks and their completion is needed.
Any suggestions appreciated.
