Power BI not showing in Power BI role center
I am trying to setup a new NAV DB that shows the Power BI Reports in the role center.
I have
1. Setup AAD authentication,
2. registered the application in AAD and given all the permissions,
3. added the content pack under the same AAD login
4. Run the Assisted setups in NAV for AAD and done the Authorize step from the Power BI part.
When I run the Select Report Action I can see the report
After that the report it just dies
Any ideas ?
