C/Front Problems in Visual Basic .NET with FieldNoArray and
wdaurer
Member Posts: 2
I'm using CFront in my Visual Basic .net Application.
I'm accessing Navision on a Microsoft SQL 2000 Server
Dataaccess to normal Datafields work with no problem.
but I'm having Problems with the Calcfields. I tried almost every notation for the FieldNoArray and CalcFields Functions. I always get the same Exception:
please help
best Regards
Wolfgang Daurer
here is the Sample Code:
=========================================================== System.Runtime.InteropServices.COMException (0x80020005): Typkonflikt. at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData) at CFRONTLib.CFRONTClass.FieldNoArray(Int32 hTable, Object& FieldNameArray) at testCFRONT.Form1.Form1_Load(Object sender, EventArgs e) in D:\ProgrammierungVB\testCFRONT\testCFRONT\Form1.vb:line 78 ===========================================================what can be wrong?
please help
best Regards
Wolfgang Daurer
Dim cf As New CFRONTClass
cf.CFrontDllName = "cfrontsql"
cf.StopOnAllExceptions = False
cf.ConnectServerAndOpenDatabase("NDBCS", "testserver", "Named Pipes", "testdb", 0, False, False, "sa", "")
cf.OpenCompany("TestCompany")
Dim tableref As Integer
cf.OpenTable(tableref, cf.TableNo("Project"))
Dim hrec As Integer = cf.AllocRec(tableref)
If cf.FindRec(tableref, hrec, "-") Then
Do
'*** Project Number
Dim val As Object = cf.GetFieldData(tableref, hrec, 1)
Trace.Write(val.ToString + " ")
'*** Project Name
val = cf.GetFieldData(tableref, hrec, 2)
'*** Customer Name from Calcfield
Dim FieldNameArray() As Object = {"Name"}
Dim array As Object = FieldNameArray
'*** the Following Line has the Error:
Dim SumFieldNoList As Object = cf.FieldNoArray(tableref, array)
cf.CalcFields(tableref, hrec, SumFieldNoList)
val = cf.GetFieldData(tableref, hrec, 58)
Trace.WriteLine("[" + val.ToString + "]")
Loop While cf.NextRec(tableref, hrec, 1) > 0
End If
cf.FreeRec(hrec)
cf.CloseTable(tableref)
cf.CloseCompany()
cf.CloseDatabase()
cf.DisconnectServer()
[/b] 0
