Documents.Open method: Problem with optional parameters
code_eater
Member Posts: 5
I want to open a word document, using .NET variables. Documentation for the command is here:
https://msdn.microsoft.com/de-de/library/microsoft.office.interop.word.documents.open(v=office.11).aspx
As you can see there, the command has a lot of optional parameters. The parameters are all of type "Object".
Has somebody an idea how to use such a function from C/AL without using all parameters or how to use placeholders?
Thx in advance
Thomas
Document Open( [In] ref object FileName, [In, Optional] ref object ConfirmConversions, [In, Optional] ref object ReadOnly, [In, Optional] ref object AddToRecentFiles, [In, Optional] ref object PasswordDocument, [In, Optional] ref object PasswordTemplate, [In, Optional] ref object Revert, [In, Optional] ref object WritePasswordDocument, [In, Optional] ref object WritePasswordTemplate, [In, Optional] ref object Format, [In, Optional] ref object Encoding, [In, Optional] ref object Visible, [In, Optional] ref object OpenAndRepair, [In, Optional] ref object DocumentDirection, [In, Optional] ref object NoEncodingDialog, [In, Optional] ref object XMLTransform );
Thx in advance
Thomas
Old thread but no answer, any idea, anybody? TQ0
I did not look any closer at the description of the function, but can you pass null values for those parameters you're not interested in?
See #8 at Vjeko's blog post Top 10 things I miss in .NET Interoperability in NAV 20130 -
Hi vaprog, with variable leaving nothing assigned in or something assigned doesn't make it work.0
For any poor souls that find this and were stuck like I was, if you're using Powershell, you can't use $null like you might think. Instead you have to use:
$missing = [System.Reflection.Missing]::Value
And substitute $missing where you would normally put $null.0
