Problem with not default printer
cyrus06
Member Posts: 3
Hi everyone.
This is my first post on MIBUSO comunity.
I'm sorry in advanced for my English! :oops:
I have a problem during the print of any report (with NAV 2013) when:
1) I select "preview"
2) I push printer button (image1) and I select a printer define "not default" on windows control panel
The Result is: "Handle not valid" (image2).
Any suggestion?
Thank a lot.
P.S. If I set the printer on Setup Printer Selections, the issue is bypassed but, in my opinion, this isn't the better way to resolve the problem...
Any suggestion?
Thank a lot.
Are you sure that the message has something to do with the printer you select?
There is a timeout, if you wait too long between starting the preview and pressing the print button. Do you get the same error message if you press preview and print the report right away?0 -
SiSt wrote:Are you sure that the message has something to do with the printer you select?
Hi SiSt.
I tryed to select the printer very quickly, but the message is the same.
If I set the same printer as "default printer" and if I wait for 10/15 sec. between preview and print... the issue doesn't exist.
It's very strange... ](*,)0
- 333 Dynamics CRM
