Documentation for project management module
poppins
Member Posts: 647
Hi everyone,
Where can I find microsoft documentation for the project module?
Thanks in advance
Thanks in advance
I often use the help for documentation. Just press F1 on an job-related page and you can see what a field means.
In help there also are procedures described. Just search in help and you will find them.
Tino Ruijs
Microsoft Dynamics NAV specialist0 -
If you are working for a Dynamics partner, you can get the documentation from Partnersource. If you are working for an end user you can get the documentation through CustomerSource. You need to have a service plan for CustomerSource, else you do not have access (see: http://www.microsoft.com/dynamics/customer/en-US/service-plans.aspx)
If you don't have access to any of the 2 options, then F1 is your only option.Best Regards,
Remco van de Ven0 -
rjmvdven wrote:If you are working for a Dynamics partner, you can get the documentation from Partnersource.
What kind of documentation do you find on Partnersource?
When I look at "Microsoft Dynamics NAV 2013 R2 Documentation" I see the following item:
System Requirements
Installation Information
Release Notes
Release Notes Follow-up
What’s New in Microsoft Dynamics NAV 2013 R2
Microsoft Dynamics NAV 2013 R2 Help Documentation
Not much there to use besides the help, or am I missing something?
Tino Ruijs
In partnersource go to Readiness & Training, and then select Training Materials. There you can select the product and find the training materials. Sometimes not all training material will be available for the latest version, then you can search in the training material from the previous version.Best Regards,
Remco van de Ven0 -
Mark Brummel wrote:Not all partners have access to this.
I think that's my case. I see only 6 items.
Tino Ruijs
- 250 Dynamics CRM
- 102 Dynamics GP
