Problem with CU5054 when using officce 2013
NaO
Member Posts: 3
I have a problem when trying to use CU5054 with Office 2013.It gives this error :
This message is for C/AL programmers:
The call to member OpenDataSource2000 failed. Microsoft Word returned the following message:
The OpenDataSource2000 method or property is not available because this command is not available for reading.
OK
When i use older version of MS Office it's not a problem but with win 8 and office 2013 i can't.Is there any solution to this problem?
OK
Our MS Office version has also been updated to 2013 and I'm seeing the same error message.
We can create attachments from 2013 and view them in an older version (2007) but cannot open them from 2013.
Has anybody else seen this or have an answer?
Thanks.0 -
follow
http://www.sagehandisoft.com.au/Opendat ... onals.aspx
http://www.dotnetmafia.com/blogs/dotnet ... eview.aspxbest regards
Franz Kalchmair, MVP
Alias: Jonathan Archer
please like / agree / verify my answer, if it was helpful for you. thx.
Blog: http://moxie4nav.wordpress.com/0
- 320 Dynamics CRM
