Problem in Running CMD Shell from Navision
pradeepkmr478
Member Posts: 13
Hi.. Good Morning.
I am working on Navision Version 2009 Classic. Running a small commad using automation "Windows Script Host Object Model'.WshShell" as WHSPradeep.
Using Code below :-
CMDReturnCode:=-1;
IF ISCLEAR(WHSPradeep) THEN CREATE(WHSPradeep);
Var1Temp:=0;
Var2Temp:=1;
CMDReturnCode := WHSPradeep.Run('Echo Pradeep Bhardwaj >> C:\text.txt',Var1Temp,Var2Temp);
CLEAR(WHSPradeep);
But i am getting error message:-
This message is for C/AL programmers:
An exception was raised in method Run. The OLE control or Automation server has returned error (HRESULT) -2147352567.
The component did not provide the exception description.
OK
Please help ....
Thanks in advance
Using Code below :-
CMDReturnCode:=-1;
Var1Temp:=0;
Var2Temp:=1;
CLEAR(WHSPradeep);
OK
Please help ....
Thanks in advance
Pradeep Bhardwaj
Pradeep Bhardwaj
Well Pradeep, what is ECHO? Is it an executable or simply a function inside the command processor?
What happens when you just execute "echo bla" in Wndows? What I mean is:
In XP use Start, Execute and enter "echo bla" or in Win 7 just open the StartMenu and enter "Echo bla" into the search field. Do not use the command processor! This is exactly what you have programmed and of course an error occurs.
What you really want is to start the command processor and have it execute the function echo.
WSH.run('cmd /c', 'echo...
Take a look here:
http://techblog.byllemos.com/2008/04/execution-of-batch-jobs-and-other-programs-from-navision/
or here:
http://dynamicsuser.net/forums/p/11946/58460.aspxFrank Dickschat
FD Consulting0 -
Thanks Frank Dickschat, It's working ..........Regards
Pradeep Bhardwaj0
- 320 Dynamics CRM
