Problem using NAVUserPassword in 2013 for authentication
Excepti0nal
Member Posts: 74
I followed this blog because I am trying to use NAVUserPassword authentication instead of the default windows authentication. I get the error listed below when trying to login though. Anyone have an suggestions?
I did have the same problem and I did was delete all certificates I created and perform the steps again. Now it works properly.
I used this link:
http://msdn.microsoft.com/es-es/library ... 70%29.aspx0 -
Thank for the reply, sorry Im so late. I am going to try this on one of my test databases and I will let you know if I can get it working.0
hi!
I get the same error after following the steps from msdn and log in through a client komputer. some said that I need to install the root CA and its revocation list on client's computer. It's done but the error presist. I can log in normally w/o error on NavServer's Windows Client.
The credential type I used is UserName. The client computer is on a workgroup while the NAV server is a Domain Controler.
Is this scenario is possible?Regards and Thanks,
Superpuz0 -
superpuz wrote:hi!
@Superpuz, did manage to have a work around?0 -
If you are working in a same domain then you can also use UserName credential instead of NavUserPassword.superpuz wrote:hi!
/Gaurav0
- 250 Dynamics CRM
- 102 Dynamics GP
