Print Body Upto Footer
JohnMclaren12
JohnMclaren12 Member Posts: 4
edited 2012-10-31 in NAV Three Tier
Hi Guys,
I am new to this Forum. And This is My first Post. Starting with an Issue. Here we go.
I have a RTC Report. It Contains Header,Body and Footer. If Its printing only one Page Its ok to have those three Header,Body and Footer in First Page. Let say it is printing Two Pages. So that the report needs to print the Footer in the last page plus In the First Page the Body needs to print up to Footer. Means that Body needs to print whole Page Upto Footer. But According to My NAV knowledge It is not possible. Normally It prints the Space of footer in every page. I have to print the body as I said upto Footer area means whole page from body other than the last page. Can some one help me on this please.
Thanks in advance... =D>
John
  • Troubles_In_Paradise
    Troubles_In_Paradise Member Posts: 588
    you're knowledge is correct. You can test the page number in order to hide footer textboxes if CurrentPageNumber <> LastPage, but RDL2005 (NAV 2009) and RDL2008 (NAV 2013) doesn't shrink automatically the footer.
    ~Rik~
    It works as expected... More or Less...
    The same question had been asked during NAV Tech Days 2012 during "Dynamics NAV 2013 Reporting Story" session.
    (http://www.mibuso.com/dlinfo.asp?FileID=1487)
    ~Rik~
  • JohnMclaren12
    Hi Rik,
    Thank You for the replies and Its now very clear to me. And also Thank you for the NAV Tech Days Video Reference.. :)
    John.
    Hi Rik,
    John.
    You're welcome :D
    ~Rik~
