Running A code unit through a LS Schedular Using NAS
Hayan
Member Posts: 110
Dear All,
I created a Job in LS Schedular and i assigned it a code unit that i created, my task is to make this code unit run automatically with other jobs, but when i assign this codeunit to a Schedular Job Type Filter HO example, it is giving an error. but if i run this Job manually from the Schedular it will be succesfull, can anybody help on this, is there any specific Criteria for running a code unit thru NAS when assigned to LSSchedular.
Best
HAYAN
Best
HAYAN
You need to modify LS Scheduler to get the last error and then see why it's erroring out in NAS.0
How do i modify it to Get Last error?0
Turn on Code coverage and see where Codeunit.RUN is run and go change that code.
If you don't have development skills contact your solution center to modify it for you.0
