Problem in advance aganist purchase order payments
varma
Member Posts: 5
Hi Friends,
I am new to Navision,
I am at client place ,
They are paying advances to vendor against purchase order,
We are having bank payment voucher applying against purchase invoice's we are applying,
But for these advance payment against purchase order i did't find option or process
can you please tell me the process how to start ...?
please help me out..
Varma....
Varma....
Did you check Prepayment Functionality?
Put prepayment % in line with payment method code( either bank or cash )then post prepayment invoice.0 -
Thank u Vijay Gupta,
I find Prepayment Invoice in Order Buttom,
But u said prepayment % in line with payment method code( either bank or cash ), should i need to write any code.
i made prepayment% Field in purchase order line there what should i do ,
Vijay can u describe in detail
Iam very much thank full to u,
varma,....0 -
I am strongly suggest you to take the senior functional consultant help in your organization.
This link will give you some idea...
viewtopic.php?f=23&t=36690&hilit=PREPAYMENT+PROCESS0 -
I also strongly suggest to read prepayments white paper
https://mbs.microsoft.com/partnersource/deployment/documentation/whitepapers/MSDNAV20095SP1PPmtsWP.htm
The link above posted by chengalasettyvsrao will give you some guidance.
However, one of the most important things to note is that if you are paying an advance (leaving a deposit) to your vendor, prepayments may have some caveats (see described in white paper).
Prepayments functionality should not be used for handling customer/vendor deposits, since it's not designed to handle such scenarios.Regards,
Ivan Koletic0
- 252 Dynamics CRM
