Help Builder - for Nav 2009 SP1 Help Toolkit
derrickderrick Member Posts: 86
edited 2012-02-24 in NAV Three Tier
Hi Experts,
I'm following the steps in the "Walkthrough: Creating and Building a New Help Topic" (the attached picture) in the NAV 2009 SP1 Help Toolkit; T_50000, T_50000_1, N_50000, & N_21 were made.
The Help Builder were successfully processed it but with 2 Lookup errors in the log file... no detail for the 2 errors so I've no clue on how important are, what are, & how to resolve them. Any help or recommendation would be appreciate. The log file:
Microsoft Dynamics NAV Help Builder 02-10-2011, 14:39:29
Processing steps
[14:39:29]:	Main log file has been created
[14:39:29]:	Configuration files have been successfully read
[14:39:29]:	Object file has been successfully read
[14:39:29]:	Detected system language settings: English (United States)
[14:39:29]:	Help Builder has finished processing at 02-10-2011 14:39:29
Summary
Processing time:
1 projects were successfully processed
0 projects were not processed
0 files not found errors
2 lookup errors
Processed projects:
Project name     Lookup errors    Files not found
addin_a                   2                    0
  • lvanvugtlvanvugt Member Posts: 774
    Hi Derrick,
    Not sure but this sounds to me like: you have some topics with some links to 2 other topics included, but these topics do not exist.
    Luc van Vugt, fluxxus.nl
    Never stop learning
    Van Vugt's dynamiXs
    Dutch Dynamics Community
  • alekpalekp Member Posts: 6
    Hi Derrick,
    You should be able to find a file called "Log.txt" in addin_a\Processed folder. In this file you will have a list of object codes that were not found in object.xml file.
    For example: if Log.txt reports T_50000 code found, it means in some of your help source files you have a token like ($ T_50000 hello world $).
    Help Builder tries to replace this token - it looks up localized caption for T_50000 object in object.xml file (object.xml file contains CaptionML properties extracted from NAV). If it can't find T_50000 in object.xml file, it will replace the token with the text that comes after object id in the token (in this example with hello world ).
    Best Regards,
    Ola Porosinska
    Software Development Engineer
