Coldfusion / Flex connection problem Nav2009 Webservices
TimSimmonds
Member Posts: 47
Has anyone had any experience of connecting a ColdFusion app to Navision 2009 webservices?
We are basically attempting to use Adobe Flex together with ColdFusion data calls to connect to a webservice. The simple test is to read data from the SystemService webservice to list out Navision companies.
It appears to be a problem with passing credentials for the data connection, although the coldfusion service user has full admin rights.
We can connect to navision webservices by other means so just wondering really if anyone else had had similair issues and if so how did they solve them?
Many Thanks
Many Thanks
Have you tried to enable NTLM authentication on the Service tier?0
Also, if it is NAV 2009 you can't adjust the NTLM authentication. Only in 2009 SP1 or 2009 R2.0
Thanks for the replies. We are running Nav2009 R2 and have tried the NTLM authentication with no luck.
Doing a basic test with Flex itself calling a webservice, works while "introspecting" the webservice. It just doesn;t work when you try to use it in a Flex component. Debug errors with "Security error accessing url" .
Strange one :-k0
