Double click problem
wilk_u
Member Posts: 94
Hey,
it can be a total newbie question but I have a problem with double click not working. I've made my own list page, it displays records from table, everything works fine. CardPageID property is set to my card, right-click for record and choosing edit displays card, same for actions->edit but when I double-click the record nothing happens. I tried to display my card from default cronus list pages with exactly the same results.
Is there an option I should change or maybe I'm just missing something?
Thank You for any help.
If you check the properties on your page then "Editable" is probably set to <Yes>. Change this to "No" and your doubleclick will probably work.
Best regards
Tommy0 -
Tried it today, that was it
Thank You
- 333 Dynamics CRM
