Problem using OCX on RTC client
ddanicaddanica Member Posts: 10
edited 2011-01-18 in NAV Three Tier
Hi!
I'm doing an upgrade from Nav 5 to Nav2009 R2 and I have the following problem:
In some objects I use methods from an OCX developed by one of my colleagues. On classic client work fine, but when I try to use it on RTC client, I receive the following error:
"This message is for C/AL programmers: The call to member [...] failed: Catastrophic failure (Exception from HRESULT: 0x8000FFFF (E_UNEXPECTED))."
I receive this error for any method that I call. The OCX is created in Visual C++. Can anyone tell me what is wrong with the OCX or in what way must be created to work?
I use windows 7 with all updates.
Thank You!
  • EgnazEgnaz Member Posts: 111
    Maybe your call of the automation has missing parameters. In Nav2009 there are 2 more paramaters for the CREATE function.
    Create(someAutomationVariable,True/False(New Server),True/False (Run on Client));
    Example:
    CLEAR(WshShell);
    IF ISCLEAR(WshShell) THEN
    CREATE(WshShell,FALSE,ISSERVICETIER);
    Have you checked this?
    egnaz
  • ddanicaddanica Member Posts: 10
    Thank you Egnaz, but CREATE is used only for automation data type. This is an OCX and I use OCX data type.
  • ara3nara3n Member Posts: 9,258
    what does the OCX do? Also OCX only instantiate at the client and not on the server.
    Yes, I need to run it on client, not on server. In this OCX I have many methods. For example, I have a method that make browse and select a folder (because in CU 412 is a function that make's browse just for a file) , I have a method that read all files form a folder, etc. All this methods work fine on classic client, the error appear just for RTC client and I have this error for all methods.
    You'll get this error because the RTC is processing such things on the service tier maschine. That's the reason why automations have the new parameters.
    In the moment I don't know a workaround for your OCX problem. Maybe you have to redesign it to work with DotNet DataType.
    egnaz
