Webservices running problem Nav 5.0
Nandkumar
Member Posts: 2
System.Web.Services.Protocols.SoapHeaderException was unhandled
Message=The server was unable to process the request due to an internal error. For more information about the error, either turn on IncludeExceptionDetailInFaults (either from ServiceBehaviorAttribute or from the <serviceDebug> configuration behavior) on the server in order to send the exception information back to the client, or turn on tracing as per the Microsoft .NET Framework 3.0 SDK documentation and inspect the server trace logs.
Source=System.Web.Services
Actor=""
Lang=en-US
Node=""
Role=""
StackTrace:
at System.Web.Services.Protocols.SoapHttpClientProtocol.ReadResponse(SoapClientMessage message, WebResponse response, Stream responseStream, Boolean asyncCall)
at System.Web.Services.Protocols.SoapHttpClientProtocol.Invoke(String methodName, Object[] parameters)
can any one answer?
thanks in Advance!
Actor=""
Lang=en-US
Node=""
Role=""
StackTrace:
can any one answer?
thanks in Advance!
NAV 5.0 doesn't have webservice capabilities. Could you give us a little more info on what you have done. THanks.0
- 320 Dynamics CRM
