Margin in Footer and No. of Rows in Body Section of a Report
shiela0325
Member Posts: 6
#-o :roll:
How can I set the margin of a certain textbox to be permanent in footer section? Is there any particular property of footer section to set this one? My problem is that everytime the detail lines in the body section becomes longer (or has mutilple entries), the footer section will adjust also to a lower margin which resulted to misalignment on the pre-printed form.
Also, may I know the differences of transfooter, groupfooter and footer in sections of a report?
In addition, how can I set the number of rows to be printed in the body section? For example: no. of lines in the body section should only limit to 7rows otherwise it will go to another page.
have you set PlaceInBottem property of footer to True?0
yes, and it works.. but how about eliminating those extra spaces between the body and footer section? The preprinted form I'm using is just half size of a short bond paper...0
- 333 Dynamics CRM
