How To solve problem about System.Drawing
QuickWEQuickWE Member Posts: 80
edited 2010-07-08 in NAV Three Tier
I would like to set the image on center of image control and then I found any solutions (it's concerned
Padding Properties) after that I do on following step by step and run that report . It showed the error look
like as following below when I clicked the preview button. I tried to search the way to solve this problem
but it does not work.
So I need your help for solved this problem and appreciate everybody who kindly help me. [-o<
P.S. The error is System.Drawing which is a trusted assembly.
