Dear All,
My requirement is to place NAV as a backened system for a co. where main appliation works on .net and SQL server. Need is to use the Navision Financials module as a separate sql server in their finacial Deptt. BUT some financial information will be done on the .net application and then it should be ported to NAV so that NAV Financials can proceed on that. Also .net application should be able to see data from NAV DB also.
I am looking for approach to develop this.
1. Will linked server work on this (I havent done this ever before)
2. How can we establish DB to DB connectivity for Real Time system
Your comments are valuable and if anyone has done this kind of job then please share with me.
How linked server works...can we populate data from other server to NAV db and vice versa...This can be helpful for a small peice of data which is not needed to processed but only informational to NAV...means no validation required....Have you tried Linked server ever?
I dont know how to setup Linked server and its preerquisites...
