Problem with Load func.
snyktp
Member Posts: 75
Hi everybody,
We have a problem with importing new files in Navision. When you are going with the classic client of Navision and you do a import of a file it goes oke ! When you are doing with RTC, it goes wrong. I think the problme is related below line. Do you have any idea about that?
FileRec.RESET;
FileRec.SETRANGE(Path,XYZ."Bestandspad XML webshop fact");
FileRec.SETRANGE("Is a file",TRUE);
IF FileRec.FIND('-') THEN BEGIN
REPEAT
XMLDOM.load(FileRec.Path + '\' + FileRec.Name);
PS : How can I use "Windows Script Host Object Model"?
Thank you
FileRec.RESET;
REPEAT
Thank you
Search C/SIDE help for UPLOAD function.0
I think the problem is releated to find function. In the classic client, the filerec.find(‘-‘) is executed on the client, but in the role-tailored client it is executed on the Reporting Service (and that is on the server).
We tested this, and it works ok in the classic client but not in the role-tailored client.
You can see the codes below.
Thank you
FileRec.RESET;
FileRec.SETRANGE(Path,CompanyInfo."XML webshop ");
IF FileRec.FINDSET THEN BEGIN
REPEAT
COPY(FileRec.Path + '\' + FileRec.Name,CompanyInfo."XML webshop + '\' + FileRec.Name);
ERASE(FileRec.Path + '\' + FileRec.Name);
UNTIL FileRec.NEXT = 0;
END;0
