Need Help using FlowField
Iqbal_Febriano
Member Posts: 66
My client needs to see their item sales and purchases according to specific salesperson and principal. So we made Global Dimension 1 Code as Principal Code and Global Dimension 2 Code as Salesperson Code.
Then, I made a form with Table 27 (Item) as Source Table and put Global Dimension 1 Filter, Global Dimension 2 Filter, and Date Filter controls. I hoped when I change the value in those controls, the Purchase (Qty.) and other fields that alike will also change accordingly.
It works fine when I typed in Date Filter control
, but when I put a value in Global Dimension 1 Filter or Global Dimension 2 Filter control, this error message showed up
I know that Item Ledger Entry table has Keys containing Global Dimension 1 Code, Item No., and Entry Type. I just couldn't find out where should I put a code to activate the key. I tried to put
in OpenForm, OnGetCurrRecord, OnAfterGetCurrRecord triggers, also in Control -Validate and AfterValidate, but it didn't work
Help me please
[color=blue]The FlowField value cannot be calculated
You must define and activate a key that contains the key fields that appear below and then associate the specified SumIndexFiled with it
Key Fields : Global Dimension 1 Code, Item No., Entry Type
SumIndexField : Invoiced Quantity
Table : Item Ledger Entry[/color]
ItemLedgEntry.SETCURRENTKEY("Global Dimension 1 Code",...)
Help me please
Be fast, be straight, be quiet
Navision automatically selects which key to use when calculating flowfields, so you can't solve it by adding code.
The problem must be in the key you have created.
When the error msg say you should "activate it", it simply means it should be enabled by having a checkmark in the keys window.
I have always been able to use this error msg very detailed. So if you have created the key as specified and remembered to set Invoiced Quantity as SumIndexField I can only find two issue left. Is MaintainSIFTIndex and MaintainSQLIndex set to yes? Is SIFTLevelsToMaintain set to maintain all levels?
Otherwise I'm blank
Peter0 -
Thanx Peter, you're right. Apparently I have enabled a wrong key
Be fast, be straight, be quiet0
- 333 Dynamics CRM
