Problem checking for 0 values in decimal field in SQL
Fi
Member Posts: 7
Hi there,
I've made a change for a customer running on NAV 2009 on SQL Server 2008, to check if any lines on a Purchase Order have a unit cost of 0. If so do not allow the PO to be released.
For lines with Unit Cost of 0.21919 say, the check if unit cost = 0 is returning TRUE?? It does not happen on Native client.
Has anyone come accross this and got around it?
Thanks in advance,
Fi
Thanks in advance,
Fi
Hi there,
I've programmed around this for the moment and seems to be working ok.
I tried using MOD function & ROUND function, to see if I could pick up decimal places somehow, but neither of these worked.
My function does the following :-
1. Format Unit Cost as text
2. Determine if there is a leading 0.
3. If Leading 0 and all characters after decimal place = 0 then unit cost is 0.
If anyone more standard way please let me know
Fi0 -
Odd... that looks like a type casting issue.
Did you try comparing the value against 0.00 instead of 0?0
