Using the IN operator - problem with decimal values
janmib
Member Posts: 8
I have a code block like this:
IF Customer.verdi<>0 THEN BEGIN
IF verdi IN [0,1..3,0] THEN range:=1 ELSE
IF verdi IN [3,1..4,0] THEN range:=2 ELSE
IF verdi IN [4,1..5,0] THEN range:=3 ELSE
IF verdi IN [5,1..20,9] THEN range:=4 ELSE
range:=5;
I compiles but does not work as planned. The field verdi is a decimal field.
We use comma as a decimal separator. Range is not set according to the
value of customer verdi.
Any tips - maybe a better way ?
range:=5;
IF Customer.verdi<>0 THEN BEGIN IF verdi > 0,1 AND verdi <= 3,0 THEN range:=1 ELSE IF verdi > 3,1 AND verdi <= 4,0 THEN range:=2 ELSE IF verdi > 4,1 AND verdi <= 5,0 THEN range:=3 ELSE IF verdi > 5,1 ABD verdi <= 20,9 THEN range:=4 ELSE range:=5;0 -
or...
if customer.verdi <> 0 then case true of customer.verdi <= 3 : Range := 1 ; customer.verdi <= 4 : Range := 2 ; customer.verdi <= 5 : Range := 3 ; customer.verdi <= 20.9 : Range := 4 ; else Range := 5 ; end ;0 -
Try
IF Customer.verdi<>0 THEN BEGIN IF verdi IN [0.1..3.0] THEN range:=1 ELSE IF verdi IN [3.1..4.0] THEN range:=2 ELSE IF verdi IN [4.1..5.0] THEN range:=3 ELSE IF verdi IN [5.1..20.9] THEN range:=4 ELSE range:=5;
The decimal separator is . not , - , is value separator. It means your code have meaningif verdi is [0 or (1..3) or 0] ...
- 333 Dynamics CRM
