help syntax problem
Hanney
Member Posts: 41
Hi there,
In navision table Detailed Vendor Ledg. Entry
field name:Doc type-option,
In properties: Option string:,Payment,Invoice,Credit Memo,Finance Charge Memo,Reminder,Refund
when i select doc type using sql like this:
select doc type from Detailed Vendor Ledg. Entry
it will display result:
doc type
1
2
3
has anybody have an idea how to display data like this:
doc type
payment
invoice
credit memo
thank you..
doc type
1
2
3
doc type
payment
invoice
credit memo
thank you..
as i know in T-SQL Arrays are not possible.
@tmpTable and fill this temp table and make then a join in the select.
A other (fast) is a the followingSELECT [Entry No_] ,[Vendor Ledger Entry No_] ,[Entry Type] ,[Posting Date] ,[Document Type] = CASE WHEN [Document Type] = 0 THEN 'BLANK' WHEN [Document Type] = 1 THEN 'Payment' WHEN [Document Type] = 2 THEN 'Invoice' WHEN [Document Type] = 3 THEN 'Credit Memo' WHEN [Document Type] = 4 THEN 'Finance Charge Memo' WHEN [Document Type] = 5 THEN 'Reminder' WHEN [Document Type] = 6 THEN 'Refund' ELSE 'WARNING NOT DEFINED' end ,[Document No_] FROM [DATABASEName].[dbo].[COMPANY$Detailed Vendor Ledg_ Entry]
Maybe it's also possible with a varchar variable and then with cast() and convert() and the IN() method. But i doesn't know this way.....
RegardsDo you make it right, it works too!0 -
Thank you..its really help.. \:D/0
Please and welcomeDo you make it right, it works too!0
@garak: Congrats with your birthday!No support using PM or e-mail - Please use this forum. BC TechDays 2024: 13 & 14 June 2024, Antwerp (Belgium)0
- 321 Dynamics CRM
