Help help help
whitekid85
whitekid85 Member Posts: 12
edited 2008-11-14 in Dynamics AX
What exactly is the thin-client and the Fat-clint in Axapta?
How to shutdown AoS service? please note i m on a standalone installation and as such hav a local server :P :)
Thx n Regdz,
  • Miker
    Miker Member Posts: 105
    It is simple. Believe me. :)
    Thin-client uses client recources (calls to/from server only for update data), and fat is the same as two tier client (calls to/from server each time).
    AOC - win service.
    going to Europe
  • kriki
    kriki Member, Moderator Posts: 9,135
    Please see Forum Rule(s) #3.1: Forum Rules and give a good title to your topic.
