Problem with Web-Parts in Employee Portal
SDauren
Member Posts: 14
Hello, everybody.
I have a problem with Employee Portal. On SharePoint website I have a card with Actions that connect to another two list web-part. When I click to one of actions both list web-parts open the same list. How can I solve this problem?
My Version is NAV 4.0 SP3.
Thanks in Advance.
Thanks in Advance.
Hi SDauren,
sorry but I do not understand your problem.
What do you want to achive?
You have a card web part which has actions. You have two list web parts which are connected to the card web part. When you click on the action, both list web parts are updated.
I guess you want to have two different actions where each of the actions is updating one list web part?
If you want to do this I must admit that this is not possible in Employee Portal.
The connections in EP are based on web part level - not on action level.
If you want to achieve my guessed way, then you have to use another solution e.g. IT IS activigence.
KR
Rainer0 -
Hi IHateLinux,
Thanks for reply.
Where I can get the IT IS activigence solution?
Thanks in advance.0 -
this is a partner add-on solution, therefore it is normally sold from the normal NAV partner. Have a look here:
IT IS AG
Rainer0 -
Thanks a lot, IHateLinux.0
- 251 Dynamics CRM
