Hi all... I'm a Ms Dynamics Nav developer and i have questions about how i have to find that Nav system works correctly.. For example: How I gotta find SQL performance? How to increase Object Cache, and if it is good solution for Nav to work better? If any ideas or any experience with that kinda stuff please be so kind and just share it with me..
Thanks a lot
MCSD
Attain Navision
I would do this:
Start reading the pdf-files coming with the installation-CD.
When you encounter something of which you want to know more, search for in on the forum. Probably you will find more info.
You can also check out the How-to and the Navision Tips&Tricks forums to have more info.
It is hard to give you easy answer. All this around is know-how which you need to collect through experiences, manuals, learning, reading mibuso... ;-)
http://www.sqlperform.nl/html/training.html
Attain Navision
