Sound beep when using confirm statement, possible?
ajhvdb
Member Posts: 672
After a process I need to inform the user about a confirm box on the screen.
I can use the beep command but haven't found the correct parameters to let it sound just like a message beep? Anyone.
ola,
dialog.beep(frequency,duration);
so..
dialog.beep(1000,10000);0 -
if (condition) then begin beep(450,100); if confirm('fsf',false) then ..... end;
normaly a sound is played, when a message (error, confirm, message) pops up. If you need to inform the user, change the duration of the beep
RegardsDo you make it right, it works too!0 -
to inform the client?0
Yes, to inform the client. Thanks for the examples but they don't sound as the message beep0
is beep still working in the 5.0 ? (i don't know if it's my laptop or the version ... ) :-k
otherwise you can use the windows movie player to play a sound ...0 -
Windows Movie Player? How About Windows Media Player!
http://www.mibuso.com/forum/viewtopic.php?t=13007
(Oldie But Goodie) - The sounds you can use are greatly increased as compared to the beep.0 -
maybe a external pop-up on the screen with a sound?0
A message beep is 2 short beeps after each other.
The standard beep(frequency,duration) looks ok but what are the parameters for:
beep(?,?);
beep(?,?);0 -
Savatage wrote:Windows Movie Player? How About Windows Media Player!
This is better than the standard NAV beep. It gets people to notice and I'm assuming that's your intention.Confessions of a Dynamics NAV Consultant = my blog
Implementing Microsoft Dynamics NAV - 3rd Edition = my 2nd book0
- 322 Dynamics CRM
