NAV 5.0 SP1 Italian - Problem with Activity Code
davidecdavidec Member Posts: 63
Hello!
My company is trying the Italian version of NAV 5.0 SP1.
We found that a new field has been added in several places: Activity Code (Codice Attività), which is mandatory when posting invoices. Its occurrences are quite frequent, so I was wondering what it's meant for. This question arises because of a "small" issue: we upgraded from NAV 4.0, so there are a lot of previous data without any associated activity code. This in turn prevents the VAT from being calculated properly (lines without the code seem to be simply ignored).
Is there a quick way to provide a default value when posting data? Is there a way to get the right VAT results even for the previous data?
Thank you very much!
  • davidecdavidec Member Posts: 63
    Problem should be solved, thanks anyway.
    BTW: The code is useless, TESTFIELDs can be commented and null values allowed in table "Activity Code". Default values are to be added in custom ways, since there's no single point these codes are connecetd to!
  • aavioaavio Member Posts: 143
    hi, am also facing same issue. :-k
    anyone plz tell me the use of Activity Code in T38,T36
    anyway am planning to comment it :whistle:
    aav!o
