How total in a body section
DarkHorse
Member Posts: 389
Hello, I'd like to know is there is any way to total the amount of a field in a body section. It's possible?.
Thanks in advance.
Thanks in advance.
YES, O:) the question is bit ambiguous, Anyway....
1)
in body - OnPreSection()TotalVariable := TotalVariable + AmountField;
This will keep adding the amount field in TotalVariable which can be used.
2) In the body section we can use record variable....and total a field of that record.
e.g.RecVar.Reset; RecVar.Setrange(.........); ........... ............. if RecVar.FindSet then Repeat TotalVariable := TotalVariable + RecVar.AmountField; until RecVar.Next = 0;
However, it is a good idea to do data calculations in OnAfterGetRecord() of the DataItem
I hope it helps.... O:)Sandeep Prajapati
Technical Consultant, MS Dynamics NAV0 -
Why in a body section? If you use a footer this goes almost automatically...look for example std. report 112.
Anyway, there are other examples like report 121 where a total is made by a new variable...
CurrencyTotalBuffer.UpdateTotal(CurrencyCode,RemainingAmt,0,Counter1);
So meaning : you create a variable where you continuously add a value and you print that :
dectotal := dectotal + amounttoadd
Small trick : check out some standard reports, if Nav can do it, you can do it!0 -
Thanks both for reply. I need to do it in a body because after, in that body, I've to do a calculation with the total amount. I'll try that you posted.
Thanks again.0
