Problem when making xml port, variable issue
Kisu
Kisu Member Posts: 381
Heyas,
I got a problem where I'd need to import an XML file that has some data in it, but the first Element of that XML file has a Version='1.2' tag on it.
VERSION is built in variable in Navision so I cant use it. So how could I get over this :-k
K.S.
  • Kisu
    --Example exported xml file from other program:
    <?xml version="1.0" encoding="ISO-8859-1" ?>
    <qwerty Version="1.2">
    <Data1> yada yada</Data1>
    </qwerty>
    --And the port on Nav 4:
    qwerty, Element, Table etc..
    -> Version, Attribute etc.. (wont work here :/ )
    -> Data1, Element, Field ...
    -> Data2, Element, Field ...
    K.S.
  • ErictP
    ErictP Member Posts: 164
    Have you tried to call the TagName "Version" and the DataSource something like "Ver1"
    OBJECT XMLport 50000 Qwerty
      OBJECT-PROPERTIES
        Date=07-05-08;
        Time=15:45:28;
        Modified=Yes;
        Version List=;
      PROPERTIES
      ELEMENTS
        { [{8C2FE5F0-DC5A-4DBE-B5D7-3109ED15C4DB}];  ;qwerty              ;Element ;Text     }
        { [{967FD65A-1B2F-4BD5-BC95-388E0BD5CCF7}];1 ;Version             ;Attribute;Text   ;
                                                      VariableName=Ver1 }
        { [{A9DB354A-0DD8-4133-A965-DE26A43C1AF3}];1 ;Data1               ;Element ;Text     }
      EVENTS
      CODE
        BEGIN
        END.
