Data Conversion permission problem
sendoh
Member Posts: 207
hi guys,
I am now upgrading from 4sp3 to 5, when I open the oldDB(4sp3) to convert the data into 5.0 it gives me an error that "you don't have permission in tempblob table". but i use our developer license and I login as SA. what should be the problem. database is SQL2005.
plz. help.
regards,
Sendoh
plz. help.
regards,
Sendoh
Sendoh
be smart before being a clever.
thanks kine..
but my problem is not still solve. any suggestion please........Sendoh
be smart before being a clever.0 -
Add a database login to the Nav database pre conversion, from MSSQL EM/MS, connect the user to the db_owner database role.
Make sure you are using a developer license that is upgraded to 5.0.
MAke sure you have lots of available disk space and just go.0
