i am working on online help file. after i created project file in Robohelp 7(trial version), i run Gate, then i got error like
"Cannot open the file "c:\ENC\addin_a\Processed\addin_a.hhc".
anyone has clue how to get rid of this error message?
Thanks for your help
When I read the documentation I thought that this file would autonatically be copied from the Source to the Processed folder, but it doesn't seem to be happening. My suggestion solved the problem for me; I hope it works for you as well.
i realized that we couldnt use addin_a file which copy from template. after reading documentation, i found that i should rename contain.hhc to addin_a.hhc. then the gate will copy that file into Processed folder.
[url][/url]
