Problem using SELECTSTR
shettarvikas
Member Posts: 106
From web service, I am getting the data into navision as a string seprated by comma (as per HL 7 format),
Eg: Cutomer Id,First Name,Second Name, Address, Address 1...email
I tried to capture the values using SELECTSTR function, but the problem is when there is a null value in between 2 comma's. The above function gives run time error. And also I saw in Help file that if the 2 values are same in the string then it also gives run time error.
Please let me kow, is there any other solution or how can it be rectified.
Thanks & regards,
Vikas
Thanks & regards,
Vikas
Hi Vikas,
You could try to use the COPYSTR function for this. I seem to recal that there is something in the Tips & Tricks forum
Edit or you could use a dataport to accomplish this
Albert0 -
Hi Albert,
I cannot use dataport, as it will take time. But using COPYSTR, can you give some more detail, like pseduocode for parsing the string..0 -
for System functions (or self defined) like copystr use the C/AL Symbol Menu (F5) :!:
Here you see all variables, Functions and when press F1 the help for System functions. There is also an understandable example.
RegardsDo you make it right, it works too!0 -
Thanks for the info. It worked0
i also had the same problem with SELECTSTR. I made a loop that replaces null values with spaces and this solved it. But now I have a new one:
when I have string like this: test1,-1,test2,test3,etc..
and I process it with the following code:
Txt := test1,-1,test2,test3,etc.. ;
Txt1 := SELECTSTR(1,Txt);
Txt2 := SELECTSTR(2,Txt);
Txt3 := SELECTSTR(3,Txt);
Txt4 := SELECTSTR(4,Txt);
The following error occurs: parameter 2 invalid for function SELECTSTR, etc...
What seems to be the problem here? -1 is the second value in a comma seperated string so I would expect it to run fine. The other strange thing is that this code ran fine for a few days and that strings containing -1 were processed correctly (and I am absolutely sure of this). Nothing has changed in the past few days, but today this error occurred. Can anyone explain this please?0
- 322 Dynamics CRM
