easy problem registering putaway in Hyperterminal using ADCS
aymane07
Member Posts: 27
Hello All;
I am sure I am having an easy/common probleme that some of you may have encoutered before.
When I try to register a put-away from hyper terminal (using the key F3) on windows 2003 I get the following message:
You cannot enter 'REGISTER' in Decimal. The cursor is in front of the invalid ch
aracter.
Thank you!!
aracter.
Thank you!!
regards,
please any one ???regards,0
here is how my miniform is designed: maybe I should add an input line for registration ???
Dépt destination/provenance Type champ N° table N° champ Long. champ Texte Ecran PCAB d'appel
Header Text 5767 2 20 N°
Body Output 5767 7305 4 AT
Body Output 5767 7301 10 Zone
Body Input 5767 7300 20 Bin Cde
Body Input 5767 14 20 N° article
Body Output 5767 15 10 Variante
Body Output 5767 16 10 UM
Body Input 5767 26 20 Qté à traiter
Body Output 5767 24 12 Qty. en suspend
thank you a lot!regards,0 -
I have solved this problem. Thanks anyway!regards,0
How did you solve the problem? Might be usefull for future reference...0
in the function group table, I changed the keyDef of REGISTER to register (it was input before) and now it works properly!regards,0
- 331 Dynamics CRM
