Compare Navision's Project Management and MS Project
hwang
Member Posts: 9
Hi all,
I know that Navision (3.7) support to Project Management via 2 grenules: Jobs and Resources.
Can you so me what is the difference between Navision's Project Management function and MS Project. What are their advantages? Which is better?
Hope to see the reply from all !
Thanks in advance!
Hwang,
Thanks in advance!
Hwang,
MS Project & Navision are really for two different purposes.
MS Project is a product intended purely for Project Management control, task management, Gantt charts, meeting deadlines etc.
Navision's Jobs & Resources is for tracking and controlling Resources and Project costs and then producing an invoice to bill the customer at the end - Budgeting & Accounting. You can produce a basic budget but you could not produce a project plan using Navision.
They are complementary products, not competeing ones.Edward Bloomfield
Lead Consultant
Theta0 -
but...
i have nav 5
project management is where in nav 5?
is in the middle of resources and jobs?
or is a navigation button appart?
thanks0 -
There is no area in NAV titled Project Management - It is handled by the Jobs & Resource Planning areas. If these do not show on your Menu Pane then either they have been hidden or you you not have the licence for them.
The Navigation button is a global feature of intended to help you search for related entries and documents - It appears in the Jobs and Resource ledgers, but is not a part of the Jobs/Resources as such...Edward Bloomfield
Lead Consultant
Theta0
