Navigation Pane Add-on module problem
srinivas.chittem
Member Posts: 142
i was created a Add-on Module and it is added into the Navigation pane
but i want a new icon set for my module..
Is there any possibility to set new icon rather than Existing..
Thank U
Thank U
srinivas
"Delighting Customers.... Through Delivery Excellence" .
srinivas
Did you mean you create new menu in navigation pane? you can change the icon by entering the number from 1 - 14 in bitmap..
example:
Caption MyModule
CaptionML ENU=MyModule
Bitmap 1Sendoh
be smart before being a clever.0 -
srinivas.chittem wrote:Is there any possibility to set new icon rather than Existing..
As sendoh said, you can specify an icon from the pre-defined ones built into the executable.
Unfortunately, there is no "real" way to specify a custom icon... ..other than hacking the exe and replacing one of the existing ones :-$0
- 333 Dynamics CRM
