I am experiencing a problem when tring to restore a navision database using SQL 2005.
The Navision Error i get when i open one of the companies is
"This message is for C/AL programmers;
Could not create an instance of the OLE control or Automation server identified by GUID={79766A7F-90D7-4143-8B23-83A78097E880}, Check that the OLE control or Automation server is correctly installed and registered."
my scenario is the following
1) I have SQL 2005 service pack 2 installed and Navision version 4.02
2) Using Navision i am creating a new SQL Navision Database
3) Using Navision i am restoring previously backed up Data common to all companies and application objects.
4) I am sure i have the correct permissions sia on SQL database and Navision wise.
5) i have the licence correctly uploaded onto SQL
6) Finally i am restoring the backup using SQL.
Please not that yesterday i successfully restored using this procedure but today i wanted to retry it to no avail. To the best of my knowledge i am following the same procedure as yesterday. I have also tried re installing SQL and navision.
Thanks to all
in 10 min this post was searchable!
http://www.google.com/search?sourceid=n ... 097E880%7d
http://www.BiloBeauty.com
http://www.autismspeaks.org
I SOLVED THE ISSUE, I HAD TO REGISTER "smtpmailxcontrol1.ocx"
